Pro´s and Con´s Widget
Hi, a Widget for showing Con´s (like “how other company´s work”) and Pro´s (“how we work”) with different color schemes.
Thanks and all the best
Hi there, @Oskar_Salomon :wave:
I guess our Pricing Table might work for this case.
You just need to disable the Price and Button elements in the settings, and you’ll get the required comparison table:
Give it a try and let me know if it worked for you :slightly_smiling_face:
Hey thanks for the suggestion - I‘ll definately give it a try :slight_smile:
All the best
Oskar
You’re always welcome :wink:
