It would be great to be able to select the amount to display per row on mobile devices.
Hi there, @FBSG and welcome to the Community ![]()
This is a nice idea! If more users get interested in this option, we’ll try to consider it in the future updates.
As for now, you can display files in 2 columns on mobile using this code in the Custom CSS field on the Appearance tab of your widget’s settings:
@media(max-width: 600px) {
.eapp-pdf-embed-grid-item {
width: 50%;
I’ve also noticed that you’ve added <style> tags to the Custom CSS field. Please remove them to make the code work correctly ![]()
