Hey, is here anyone else who has problem with the widget? I tried to place the widget on different Wordpress sites (with Elementor) and it is not showing up. I do not even see the preview link! It looks like the exact feature we need and I even paid Basic plan to reach support, unfortunately none of the buttons for support is working. Is something going on with Elfsight and should I just keep looking? Of course I need it as soon as possible.
Hi @Admin_YouSelect, Iâm so sorry to hear about this unfavourable experience ![]()
Unfortunately, our Support Team has received an unexpected influx of support messages, which is why response times may be longer than usual. My apologies for this.
As for the issue with the Calculator widget, could you please send me the link to the website where itâs installed? Iâll be happy to look into this for you!
Hello Helga. We solved it. In fact if there is any add blocker in the browser, your widged does not runâŠNow we are experiencing something different. I know you can make some kind of OR logic. Unfortunately the real OR is still missing. I know I can switch between ALL and ANY. The fist is clear. The second not that much. Even I make the logic âshow wen A and Bâ I still see it when I have C. I am now really struggle to finish the calculator I am making.
Hi there, @Admin_YouSelect ![]()
Could you please describe in more detail what youâd like to achieve and share a specific example of the field/calculation from your widget, where youâd like to set up this conditional logic? Iâll be happy to check things for you ![]()
I am making a pool calcutator. I have 3 main types of pool. Two types are simple and ready. But the third one has more options (4 types, 2 colors, 8 sizes etc.). For now I need to make logic: Depth 1 m or 0.8 m (each has different price for different size of pool). But it does not matter what size of pool I put in condition it is always showing up. For example I put in that it should be shown only if the depth is 1 m and 3 meters long but it shows up every time the type of pol si selecter never mind the lenght.
If I got you right, youâd like to show a specific field only if both conditions are met (depth is 1m, length is 3m).
Since you havenât finished your widget yet, Iâve created a test calculator based on your description, where everything works great:
If youâve set up the conditions the same way, but the issue still persists, or if I misunderstood your idea, please specify the name of the field which should be hidden ![]()
Thank you for your time. I also have the same size (3 meters lenght), the same depth (1 m) but two colors. So I have to put 2 times 3 m pool. That should not be the problem. But the problem is, that even I have pool 4 m it is still showing up. Can you see the calculator I made?
This is what is happening. You can see I set only size 3 . but when I try 4 m in my calculator, it still shows the fieldâŠ
Thanks for the clarification!
This issue occurs because of the default values set for the âWĂ€hlen Sie eine Grösse fieldsâ. To better demonstrate it, Iâve added the numeration to the âWahlen SieâŠâ and âAbdeckungenâŠâ fields. Feel free to remove the numeration once you check things ![]()
Here is a screenshot of the conditional logic set for the âAbdeckungen fĂŒr Badebrunnen 2â field:
As you can see, Iâve chosen Badebrunnen 365 Tage pool with the size 3.0x2.4m (BadeflĂ€che: 2.070x2.105m)
Based on the conditional logic from the screenshot above, only âAbdeckungen fĂŒr Badebrunnen 2â field should appear.
Here is a conditional logic for the âAbdeckungen fĂŒr Badebrunnen 1â, showing that this field shouldnât show up, but itâs still displayed:
This happens, because the âWĂ€hlen Sie eine Grösse Badebrunnen 365 Tage 6â field has the default value 3.0x2.0m (BadeflĂ€che:2.070x1.705m), which makes the âAbdeckungen fĂŒr Badebrunnen 1â field appear, even if the necessary size isnât chosen in the calculator:
To fix this issue, you should change the default value in your Wahlen Sie (5 and 6) fields (for example, to None):
Let me know if this explains things or if you have any questions left ![]()
Thank you. One of my problems is solved. Can you please have a look at my settings once again? I need to pick depth (1m or 0.8m) and size of the pool and I have more of them. If I apply ALL, nothings shows. If I apply ANY every solution is shown due to the depth settings. Do I really do for each pool the settings extra? That would be a night mare.
So I played it a little bit. Not as smooth as I wanted it but it is working. The only problem now is the formula. Showing - when there should be price shownâŠthe generator is nor helping. I need to show the price from the step where the pool size is picked. Never mind there are some choices missing.
Do I get it right, that you mean the Total and Pool Preis Calculations? Do you want to completely hide them before the pool size is chosen or youâd like to display 0 or â-â instead?
