Widget for reviews from Meetup.com
Request for a widget that brings reviews from Meetup.com into Squarespace
Hi there, @Mike_Hudson :wave:
As far as I see, Meetup doesn’t have a built-in feature for leaving reviews like on Google. However, I’ve found users can provide feedback about events and groups through comments or discussions.
Is it what you were looking for?
Hi Max
Firstly, thank you for your quick reply.
Meetup has a review section. I have added a link here.
https://www.meetup.com/aaa-outdoor-hiking-adventure-travel/feedback-overview/
Would it be possible to extract data from here?
Regards
Mike
Unfortunately, there is no way to pull reviews from Meetup now. However, if this idea gains more votes, it might be considered in the future :slightly_smiling_face:
As a workaround, you can use a Custom Source option in our All-in-One Reviews app and add the needed reviews manually. Feel free to check it out:
