Hi
What can I do to make the widget Business Hours responsive?
If that is not possible, Is there a way to abbreviate the names of the months? Like:
januari > jan
februari > feb
maart > mrt
april > apr
mei > mei
juni > jun
juli > jul
augustus > aug
september > sep
oktober > okt
november > nov
december > dec
Website: https://cremerieoostende.be/
Thank you
Lieve
I’ve forwarded the issue with text cropping to the devs and will let you know once it’s fixed.
As for now, you can reduce the font size on mobile to fix the issue using this code in the Custom CSS field on the Style tab of your widget’s settings:
