Why isn't Pinterest embedding working?
This is what the system says:
" Please, set correct user to display in the widget.
Free Pinterest Feed widget"
The free plan allows 1 widget, so I don’t understand.
Hi there @user13966 and welcome aboard :wave:
You just need to replace the link you’ve added to the Profile field with your profile name:
Hello,
Thanks. However, embedding is not yet possible.
And there is nothing on the “boards” page yet.
Why can’t you upload a picture??
https://1drv.ms/i/s!AhcnICgoGI51i5EmX-pTlFjfHkL2NQ?e=hbjJUC
You’ve added a link to your profile to the Board field, but you haven’t got any boards in your account:
image image
If you remove this link, your Pinterest profile will be displayed correctly:
And how can I add boards?
Where can I access the embed code?
I would like to embed it in my Framer website.
To display a specific board in your Pinterest Feed, you just need to add a link to your board to the Board field:
However, currently, you don’t have any boards in your Pinterest profile, that’s why you can’t display them:
You can find your widget’s installation code right in the dashboard. Just click 3 dots next to your widget, choose Embed Code and copy it:
You can find installation tutorials for different platforms under the installation code:
If you haven’t found your platform, you can request installation and our Support Team will be happy to assist you with it.
Let me know if you have any questions left :slightly_smiling_face:
Thanks.
Yes, there is no board on the apinterest channel, that was the problem.
I just picked one to test.
I couldn’t find a video about embedding in Framer, even though Framer is very popular.
So far I don’t know where to insert the code.
In this case, we’ll be happy to assist you with it!
Just request the installation right from the dashboard (see the screenshots from my previous message) and our support agents will contact you and pass your request to the devs :slightly_smiling_face:
