Would it be possible to add Which reviews eg:
Hi there @Peter_Garner ![]()
Thanks for adding your idea to the Wishlist!
We’ll try to consider this source for the future updates. We’ll keep you posted here in case of any news ![]()
As a workaround, you can use a Custom Source option in our All-in-One Reviews app and add the needed reviews manually. Feel free to check it out:
