Which Elfsight plugins are now ADA (WCAG) compliant?
I know Elfsight is trying to make their widgets compliant. Can we have a list of the ones that are and the timeline for those that aren’t? I need to know which ones I need to remove. Thank you.
Of the ones we use, I’ve been told these are fixed. I will have my WCAG team audit them to confirm and report back.
  1. Instagram feed
  2. Google reviews (not sure if this also applies to the slider widget)
  3. Popup
  4. Events
Not done yet (please let me know of others to add. As they get updated, I’ll move them to the top list.):
  1. Youtube gallery
Hi @Kelli :raised_hands:t2:
I have to admit that, unfortunately, our widgets are not fully ADA-compliant out of the box. However, you can customize the widgets to make them more accessible for screen readers using the settings available in each widget.
The thing is that ADA compliance requirements can vary by country, which makes universal compliance quite challenging.
But the good news is that our developers will be happy to adjust the widgets according to your requirements if it’s possible. So could you please describe what you’d like to change in what widgets (i.e. alt text, bigger size of the elements, etc.)? We’ll try our best to adjust things for you!
