We want to invert the tracks order in Audio Payer
We use the Audio Player app. The tracks that we enter are ordered from oldest to most recent. We would like it to be the other way around, for the most recent to be ordered first in the list.
www.jacatimes.es
Hi @Felix_Gutierrez, and welcome to the forum!
Am I right that you’d love to change the order of the downloaded tracks in your widget editor so it’s easier for you to navigate?
If you had something else in mind, please elaborate on your use case a bit so that I understand it better :slight_smile:
The matter is easy. If the normal order of traks appear as 123456… I want to change it as 654321. ¿How to do iy?
Thank you for your reply, I got you!
I’m afraid there is no option to revert the track order at the moment, but I’ve moved your idea to our wishlist so that our devs take it under consideration. I’ll post here if I have any news :slight_smile:
Thank you very much for your help!
