Vertical Centering - Formatting Issue w/ Announce Bar
  • Issue description:
Starting in the last 2 or 3 days, our announce bars have started to have some funky formatting with the text no longer properly vertically centered. Is there a larger issue?
I’ve got others if needed.
Hi there @Chris_Murphy :wave:
Yes, it would be great if you could share links to another pages where the issue occurs :pray:
These are 3 separate announcement bar widgets.
Thank you so much!
Our devs will investigate the issue. I’ll keep you updated :slightly_smiling_face:
I’m experiencing a similar problem on my website where the text in the Announcement Bar isn’t displaying correctly.
https://go.anyarabic.com
Hope this can be fixed soonest
Hi @Haytham :wave:
I am so sorry for about all the inconvenience!
I’ve shared your case with our devs as well. I’ll keep you in the loop!
Hey guys @Haytham @Chris_Murphy :wave:
We’ve fixed the issue by adding this code to the Custom CSS field on the Style tab of your widget’s settings:
[class*="bar-elements__ElementsWrapper-sc"] {
  height: auto !important;
Please check your widgets and let me know if they are fine now.
It’s a temporary solution of the issue. Once the global fix is applied, I’ll let you know right away :slightly_smiling_face:
Yes, I think it is back to normal now.
Thanks.
https://go.anyarabic.com/
Great! You are always welcome :wink:
Looks good on my end this morning. Thx for the temp fix!
Hey guys :wave:
The issue is globally fixed! Now you can remove the CSS codes from your widgets :slightly_smiling_face:
