Can you add an option to change the list background color to be transparent
Hi there @backhome84 ![]()
This code should help:
[class*='background__Container-sc'] {
box-shadow: none;
background: none;
Please add this code to the Custom CSS on the Settings tab of your widget’s setting and let me know if it helped ![]()
