Is there a way to move the pop-up and the zoom controls down about 35px. Since the is no navigation to go back to the website, I improvised and overlayed a a menu at the top. However, that covers up most of the zoom controls and a little over half of the pop-up close button are showing. Is it possible to move them down via custom css?
And nothing pisses me off more then a message that can’t be deleted or edited!!!
Hi @jamesn1027 ![]()
I am really sorry about all the confusion, however, I am glad to see that you’ve managed to delete your message. Just in case, here is the button that allows you to edit your message:
As for the code, I’ve checked it, and it works great on my end:
Could you please double-check it? If the issue still persists, please send me a link to the page where your widget is installed or specify its ID.
@jamesn1027 Sure, we’ll be happy to help!
Could you just send me a link to the page, where your widget is installed?
I’m going to try an explain this one more time… I do not want to make the modal smaller. I want to move it down!
You’re referring to the case described in this thread, right?
If it is, please send me a link to the page where your widget is installed. We’ll be happy to check things for you ![]()
OMG… You do not need access. You need to give me the id for the modal so I can move it down.
Here is the code to move down the location popup:
[class*="Popup__PopupContent-sc"] {
top: 35px !important;
bottom: 0 !important;
And this code will help you move down zoom controls:
.maplibregl-ctrl-top-right {
top: 35px;
Please check it out and let me know if it worked ![]()
Yay! Finally worked… Thank you, Sir!
You’re always welcome!
If anything else comes up, we’ll be more than happy to help ![]()
I have to apologize to you Max, it never dawned on me to look at the code for the page. Usually, the widget is not available to the user.
That’s okay ![]()
