A 1:1 clone would be great, though, so we wouldn’t have to go through the learning phase twice. As a copy, it would only use the same color settings.
Hi there, @Ekkehard ![]()
Thanks for sharing your thoughts!
You just need an option to copy a widget with the existing knowledge base, so that you could quiclky change some style/layout settings only, right?
If so, this idea is already on the Wishlist and you can upvote it here - Duplicate the widget with the Knowledge Base
