Text and form fields aren't properly aligned
That CSS code did not work for me. Is there another way to solve the problem? margins, padding, full width. The form looks fine in elfsight, but when I put the code in my ClickFunnels site it centers.
Hi there, @Virginia_Nanette and welcome to the Community :waving_hand:
The CSS code you were trying to use aligns the widget container, and as I see, it worked fine in your widget.
However, there is an issue with form fields alignment, which occurs because of the margin: 0 auto; style applied to all containers on your website:
To fix this issue, you should disable this style on your website. Please try it out and let me know if it helped :wink:
