Target individual elements when using the “multi tables mode”?
Hey, I’m using the new Grid layout for my pricing table. Is it possible to customise the individual columns when using the “multi tables mode”?
For example I can use this CSS below to target the first column title, but it also applies to the first column of the second page in the “multi tables mode”. What do I need to add to the beginning of the CSS to say just target the 1st or 2nd page, column 1 title of the pricing table? Hope that makes sense.
.es-column-container:nth-child(1) .es-title {
color: #29be98;
Thanks in advance!
Happy to see you in our Community! Welcome, @user14676 :waving_hand:
This CSS code should do the trick:
.es-widget-container:has(> .es-toggles-container > [role="button"]:nth-child(2) .es-toggles-toggle.es-toggles-toggle-active)
.es-column-container:nth-child(1) .es-title{
 color: #29be98;
Give it a try and let me know if it worked for you :wink:
