Tags position and visibility
  1. Is there a way via custom CSS i can hide the tags from showing on the events tiles but still show in the popup when viewing just one selected event?
  2. Is there a way to order the content on the event popup so that the tags show below the event description rather than above the event description?
I got the tags to hide on the event tiles but still show on the popup using the below:
/* Tags display*/
.eapp-events-calendar-tags-component {
display: none;
So now just need help with the order of the content in the actual popup!
Here is the CSS code to change the order of the tags and description in the popup:
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-popup-item-inner {
  display: flex;
  flex-direction: column;
.global-styles,
.eapp-events-calendar-modal-modalContent [class*="edit-item-button__Container-sc"] {
  order: 1
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-close-component {
  order: 2;
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-popup-item-header {
  order: 3
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-popup-item-media {
  order: 4
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-tags-component {
  order: 6;
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-popup-item-description {
  order: 5;
  margin-bottom: 20px;
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-popup-item-row {
  order: 7;
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-popup-item-mapContainer {
  order: 8;
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-organizer-component {
  order: 9
.global-styles,
.eapp-events-calendar-modal-modalContent .eapp-events-calendar-divider-component {
  order: 10;
Please add it to the Custom CSS field and let me know if it worked :wink:
As for showing/hiding tags, you don’t have to use a CSS code since the widget includes options to control the display of the widget elements in the event cards and popups:
