Hey there, @user23274 ![]()
Thank you so much for sharing your example with us!
We already have a similar request on the Wishlist. Iāve moved your comment to the related thread, where weāll keep you updated ![]()
Footer with three or four tabs
Hey there and welcome to the Community, @Michael_Link ![]()
Glad to say that this idea is already on the Wishlist! Iāve merged your comment with the existing request, where weāll keep you updated ![]()
Welcome to the Community, @Ryan_Hundven ![]()
Thanks a bunch for sharing your use case!
We already have a request for the Tabs widget. Iāve merged your comment with the original request, where weāll keep you updated ![]()
I see that this has been under consideration for quite some time, but Iād like to bump it to the top and explain my use case. I have a page on one of my sites that contains a lot of important information, but itās looong. I have partially broken it up by adding an accordion TOC at the top of the page, but itās still long. Iām envisioning the page laid out with the accordion links pointing to in-page anchors that would display each topic and subtopic (H2, H3) in a tab format. This would shorten it considerably and add visual interest. I also need it to be accessible⦠keyboard navigation, full Aria for screen readers, etc.
Iāve started coding it myself but am discovering thereās more than initially meets the eye (which is probably part of the reason you havenāt released it yet
). As far as customization, nothing special, the normal Elfsight degree of user customizing would be fine. Hereās an example UI that would be perfect. It provides color differential between tabs and also elevates the selected tab a bit to visually reinforce it as selected.
Hi there, @Bob_Wilson ![]()
Thanks a lot for sharing the details of your use case with us!
I completely got what you mean and weāll try to consider your suggestions when working on this request ![]()
Please consider creating a widget that lets users add tabs with data. I want to add tabs like the ones beneath āExplore Listingsā on this website.
Thanks
Hey there, @Solomon1 ![]()
We already have a request for the Tabs widget on the WIshlist. Iāve merged your comment with the existing thread where weāll keep you in the loop ![]()
