To have concept status per locations. To be able to hide per locations instead of having to delete them and add again when a locations is closed for while.
Hi there, @user30916 and welcome aboard ![]()
Thanks for adding your idea to the Wishlist!
Are you looking for a way to enable/disable Working Hours along with the Close/Open status, or you wanted to keep working hours and remove status only?
