Horizontal forms are a great fit for desktop, but they may not look as good on mobile due to limited screen space. Fields can become too narrow, causing horizontal scrolling or cut-off labels.
A simple solution is to switch the fields to a vertical layout on mobile.
To implement it, just add this code to the Custom CSS field on the Appearance tab of your widget’s settings:
@media (max-width: 600px) {
[class*="HorizontalLayout__Grid-sc"] {
display: flex !important;
flex-direction: column;
gap: 10px;
[class*="HorizontalLayout__HorizontalSubmitButton-sc"] {
margin: 0 !important;
.es-field-layout-container {
padding: 0 !important;
That’s it! Now your form is displayed vertically on mobile and horizontally on desktop ![]()
Guys, was this solution helpful? Let us know in the comments
