Squarespace Two Rows Carousel
Description
  • two rows carousels, you can set carousel with image only or carousel with image, text, button
  • view demo – password: abc
#1.1. First add Section > Choose Team > Choose Section with (i) icon
#1.2. Hover on top right of section > Click EDIT CONTENT
#1.3. at Design > Choose Carousel
#1.4. at Elements > You can Enable Image or Image, Title, Button, anything what you want. But Image is required.
#1.5. at Content > Add your desired title, image, button url
#1.6. Add word: row-1 or row-2 to Image ALT
This will determine whether the image will be in Row 1 or Row 2.
Like this
or this
or this
#1.7. Hover on Page where you use Carousel > Click Gear icon
#1.8. Click Advanced > Paste this code
  • If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
<!-- 07.26c11v2 2 Rows Carousel -->
window.TWO_ROWS_CAROUSEL_CONFIG = {
  slidesPerViewTablet: 2,
  slidesPerViewMobile: 1,
  tabletBreakpoint: 640,
  desktopBreakpoint: 1024,
<script src="https://code.beaverhero.com/list/0726c11v2tworowscarousel.js"></script>
<style>.trc-1 {padding-left: 2vw;padding-right: 2vw;}</style>
#2. Customize
#2.1. If you see space between arrow – first row/arrow – second row is not equal, you can change option to 0
#2.2. To change number of columns on desktop/mobile, you can change these lines (Line 04, Line 05)
#3. Other
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit current page (page where you use Carousel) > Add a Block > Choose Markdown
Add this code into Markdown
