To open Summary Lightbox on List button click, like this
You can follow these steps.
#2. Add Summary Block
#3. Edit each item button > Click Attach Link
Enter popup url, use this format: #popup-hover=/popup-content
/* Popup style */
.popup-overlay {
position: fixed;
top: 0;
left: 0;
width: 100%;
height: 100%;
z-index: 9999;
opacity: 0;
visibility: hidden;
transition: all 0.3s ease;
.popup-overlay.show {
opacity: 1;
visibility: visible;
.popup-modal {
position: absolute;
top: 50%;
left: 50%;
background: #fff;
border-radius: 12px;
max-width: 1200px;
max-height: 80vh;
width: 90%;
overflow: hidden;
.popup-modal:hover {
.popup-header {
position: relative;
padding: 20px 50px 20px 20px;
.popup-close {
position: absolute;
top: 15px;
right: 15px;
width: 30px;
height: 30px;
border: none;
background: transparent;
font-size: 18px;
cursor: pointer;
display: flex;
align-items: center;
justify-content: center;
border-radius: 50%;
.popup-close:hover {
background: #f0f0f0;
.popup-content {
padding: 20px;
max-height: 60vh;
overflow-y: auto;
line-height: 1.6;
.popup-loading {
text-align: center;
padding: 40px 20px;
color: #666;
font-style: italic;
.popup-error {
text-align: center;
padding: 40px 20px;
color: #e74c3c;
font-style: italic;
You can also use Popup plugin instead, so you can do Summary Lightbox on List button click easier without using complex code.
async function initializeContent(contentElement){try{if(typeof ss$!=='undefined'&&ss$.reloadSquarespaceLifecycle){await ss$.reloadSquarespaceLifecycle(contentElement)}else if(typeof Squarespace!=='undefined'&&typeof Y!=='undefined'){Squarespace.initializeLayoutBlocks(Y);Squarespace.initializeCommerce(Y);const formBlocks=contentElement.querySelectorAll('.sqs-block-form');if(formBlocks.length>0){Squarespace.initializeFormBlocks(Y,Y.one(contentElement))}}
setTimeout(()=>{const scripts=contentElement.querySelectorAll('script');scripts.forEach(script=>{if(script.textContent&&!script.src){try{eval(script.textContent)}catch(e){console.warn('Script execution failed:',e)}}})},100)}catch(error){console.error('Content initialization error:',error)}}
const contentDiv=popupOverlay.querySelector('.popup-content');contentDiv.innerHTML=content;popupOverlay.classList.add('show');document.body.style.overflow='hidden';await initializeContent(contentDiv)}
const cache=new Map();async function fetchPopupContent(){const cacheKey=CONFIG.popupPageUrl;if(cache.has(cacheKey)){return cache.get(cacheKey)}
try{const response=await fetch(CONFIG.popupPageUrl);if(!response.ok)throw new Error(`HTTP ${response.status}`);const html=await response.text();const parser=new DOMParser();const doc=parser.parseFromString(html,'text/html');const mainContent=doc.querySelector('#page .page-section')||doc.querySelector('main')||doc.querySelector('.sqs-layout');if(mainContent){const content=mainContent.innerHTML.trim()||'No content found';cache.set(cacheKey,content);return content}else{throw new Error('Content not found')}}catch(error){console.error('Fetch failed:',error);throw error}}
const popupLinks=document.querySelectorAll('a[href*="#popup-hover"]');popupLinks.forEach(link=>{link.addEventListener('click',async function(e){e.preventDefault();showPopup('<div class="popup-loading">Loading...</div>');try{const content=await fetchPopupContent();showPopup(content)}catch(error){showPopup('<div class="popup-error">Failed to load content</div>')}})});document.addEventListener('keydown',function(e){if(e.key==='Escape'&&popupOverlay&&popupOverlay.classList.contains('show')){hidePopup()}})});</script>
