To open Product popup on Header button click, like this.
#1. First, create a page with Name/URL: Popup Content β /popup-content
#2. Add Product Block then find IDs
#3. Next, click on Header button > Click Link icon
Enter popup url, use this format: #popup-hover=/popup-content#enter-product-block-id
For example: #popup-hover=/popup-content#block-yui_3_17_2_1_1755054421758_1389
/* Popup style */
.popup-overlay {
position: fixed;
top: 0;
left: 0;
width: 100%;
height: 100%;
z-index: 9999;
opacity: 0;
visibility: hidden;
transition: all 0.3s ease;
.popup-overlay.show {
opacity: 1;
visibility: visible;
.popup-modal {
position: absolute;
top: 50%;
left: 50%;
background: #fff;
border-radius: 12px;
max-width: 500px;
max-height: 80vh;
width: 90%;
overflow: hidden;
.popup-modal:hover {
.popup-header {
position: relative;
padding: 20px 50px 20px 20px;
.popup-close {
position: absolute;
top: 15px;
right: 15px;
width: 30px;
height: 30px;
border: none;
background: transparent;
font-size: 18px;
cursor: pointer;
display: flex;
align-items: center;
justify-content: center;
border-radius: 50%;
.popup-close:hover {
background: #f0f0f0;
.popup-content {
padding: 20px;
max-height: 60vh;
overflow-y: auto;
line-height: 1.6;
.popup-loading {
text-align: center;
padding: 40px 20px;
color: #666;
font-style: italic;
.popup-error {
text-align: center;
padding: 40px 20px;
color: #e74c3c;
font-style: italic;
You can also use this Popup plugin instead, so you can do Product popup on Header button click easier without using complex code.
<script>document.addEventListener('DOMContentLoaded',function(){const CONFIG={popupPageUrl:'/popup-content'};let popupOverlay=null;function createPopup(){const overlay=document.createElement('div');overlay.className='popup-overlay';const modal=document.createElement('div');modal.className='popup-modal';const header=document.createElement('div');header.className='popup-header';const closeBtn=document.createElement('button');closeBtn.className='popup-close';closeBtn.innerHTML='Γ';closeBtn.addEventListener('click',hidePopup);const content=document.createElement('div');content.className='popup-content';header.appendChild(closeBtn);modal.appendChild(header);modal.appendChild(content);overlay.appendChild(modal);document.body.appendChild(overlay);overlay.addEventListener('click',function(e){if(e.target===overlay){hidePopup()}});return overlay}
