We can use this code to Code Injection > Footer. This code will work with List Section Banner Slideshow Only.
(function() {
let playInBackend = true,
timing = 3,
section = '',
direction = 1;
function FadeSlideshow(sectionSelector) {
const section = sectionSelector === ''
? document.querySelector('.user-items-list-section')
: document.querySelector(sectionSelector);
if (!section) return;
const slides = section.querySelectorAll('.slide');
const arrowButtons = section.querySelectorAll('button[class*="__arrow-button"]');
let timer;
let interval = timing * 1000;
let isPaused = false;
let isVisible = true;
let isEditMode = false;
let isModalOpen = false;
setupFadeEffect();
initEventListeners();
startTimer();
setupIntersectionObserver();
function setupFadeEffect() {
const style = document.createElement('style');
style.textContent = `
.fade-slide {
opacity: 0;
transition: opacity 0.8s ease-in-out !important;
transform: none !important;
.fade-slide.active {
opacity: 1;
z-index: 1;
.slides {
position: relative;
.slide {
position: absolute;
top: 0;
left: 0;
width: 100%;
.slide:first-child {
position: relative;
document.head.appendChild(style);
slides.forEach((slide, index) => {
slide.classList.add('fade-slide');
if (index === 0) {
slide.classList.add('active');
if (slide.style.transform) {
slide.style.transform = 'none';
function initEventListeners() {
document.addEventListener('visibilitychange', function() {
isPaused = document.hidden;
['mousedown', 'touchstart'].forEach(event => {
section.addEventListener(event, function() {
isPaused = true;
['mouseup', 'touchend'].forEach(event => {
isPaused = false;
clearInterval(timer);
startTimer();
if (arrowButtons.length >= 2) {
arrowButtons[0].addEventListener('click', function(e) {
e.preventDefault();
e.stopPropagation();
goToSlide(getCurrentSlideIndex() - 1);
arrowButtons[1].addEventListener('click', function(e) {
e.preventDefault();
goToSlide(getCurrentSlideIndex() + 1);
function startTimer() {
timer = setInterval(autoAdvance, interval);
function autoAdvance() {
isEditMode = document.querySelector('body.sqs-edit-mode-active');
isModalOpen = document.querySelector('.sqs-modal-lightbox-open, .wm-mega-menu--open');
if (!isPaused && !isEditMode && !isModalOpen && isVisible) {
const nextIndex = direction === 1
? (getCurrentSlideIndex() + 1) % slides.length
: (getCurrentSlideIndex() - 1 + slides.length) % slides.length;
goToSlide(nextIndex);
function getCurrentSlideIndex() {
let currentIndex = 0;
if (slide.classList.contains('active')) {
currentIndex = index;
return currentIndex;
function goToSlide(index) {
const normalizedIndex = (index + slides.length) % slides.length;
slides.forEach(slide => {
slide.classList.remove('active');
slides[normalizedIndex].classList.add('active');
const liveRegion = section.querySelector('[aria-live="polite"]');
if (liveRegion) {
liveRegion.textContent = `Item ${normalizedIndex + 1} of ${slides.length}`;
function setupIntersectionObserver() {
if (window.IntersectionObserver) {
const observer = new IntersectionObserver((entries, observer) => {
entries.forEach(entry => {
isVisible = !!entry.isIntersecting;
rootMargin: '-75px 0px -75px 0px'
observer.observe(section);
window.addEventListener('load', function() {
let sections = new Array();
sections.push(section);
if (section.includes(',')) {
sections = section.split(',');
sections.forEach(sectionSelector => {
if (window.top == window.self || (window.top !== window.self && playInBackend)) {
new FadeSlideshow(sectionSelector);
