When you need to target a section in Squarespace, you will need to use [data-section-id].
When you need code that affects multiple sections, you will need to use [data-section-id1], [data-section-id2,…
If you intend to build templates to sell to customers, your customers will need to learn how to find data-section-id, which will be annoying for them.
You can use this code to assign a class name to a specific section
First, add a Code Block to section where you want to assign class name
<div class="section1"></div>
Next, add this code to Website Tools > Code Injection > Footer
jQuery(document).ready(function($){
$(".code-block .section1").parents(".page-section").addClass("section1");
$('.code-block .section1').parents('.code-block').addClass('hide-code-block');
<style>
.hide-code-block {
display: none !important;
</style>
These code mean
- Find a Code Block, if Code Block code contains class “section1”, then add this class name to Section Tag
- Find a Code Block, if Code Block code contains class “section2”, then add class name: hide-code-block
- Remove Code Block
and when you want to use data-section-id, just use this class name instead
section.section1
