To add Gradient Color to Navigation Links, like this.
You can use this code to Custom CSS box.
If code doesn’t work, you can comment below, message or send me an email.
div.header-nav-item a, div.container.header-menu-nav-item a div {
background: linear-gradient(45deg, #ff6b6b, #4ecdc4);
-webkit-background-clip: text;
-webkit-text-fill-color: transparent;
