To add a gradient on a text block, you can follow these.
#1. Specific Text Block
First, find ID of Text Block.
In my example, we will have: #block-yui_3_17_2_1_1739950653718_1742
Next, use CSS code like this. (You can change color in the code)
If code doesn’t work, you can comment below, message or send me an email.
background-image: linear-gradient(to right, red , yellow);
padding: 5px 10px;
#2. Multiple Text Block with Same Gradient
Instead of having to find the ID of multiple Blocks. You can do the following.
First, add ## symbol at bottom of text.
Highlight ## > Click Link icon > and enter URL: #gradient
Next, use this code to Custom CSS box.
/* Gradient text */
:root {
--gradient1: red;
--gradient2: yellow;
div.html-block:has(a[href="#gradient"]) {
background-image: linear-gradient(to right, var(--gradient1), var(--gradient2));
padding: 5px 10px;
a[href="#gradient"] {
display: none;
Remember to change color
Result
