Description
- flip text block with hover (desktop), click (mobile), use symbol # to recognize flip
- view demo – password: abc
#1.1. Make sure you added some Text Blocks with symbol like this
- #1front#
- #1back#
- #2front#
- #2back#
These will help the code identify the Text objects that need to be flipped.
#1.2. Make sure Text Blocks for Front/Flip overlap together
#1.3. Hover on top right of section > Click EDIT SECTION
#1.4. at Design > Anchor Link > enter word: flip-text
#1.5. Next, use this code to Page Header Injection (page where you use Text Block)
- If you use Personal/Basic Plan and your plan doesn’t support Injection, you can see #3.1
<!-- 07.26c10v1 Flip Text Block -->
window.FlipTextBlockConfig = {
containerSelector: '.fluid-engine',
blockSelector: '.fe-block',
markerRegex: '#\\s*(\\d+)\\s*(front|back)\\s*#',
autoHideBackOnParse: true,
animationClasses: ['preFlex', 'flexIn'],
disableInnerTransitions: true,
replaceTextShapes: true,
replaceShapes: ['underline'],
textShapeSelector: '.TextShape-node',
highlightSelector: '.sqsrte-text-highlight',
underlineOffset: '0.16em',
underlineThickness: '0.1em',
perspective: '1400px',
duration: 700,
easing: 'cubic-bezier(0.19, 1, 0.22, 1)',
axis: 'Y',
flipDirection: 1,
desktopTrigger: 'hover',
mobileTrigger: 'tap',
hoverMediaQuery: '(hover: hover) and (pointer: fine)',
tapToggle: true,
closeOnOutsideTap: true,
keyboardAccessible: true,
ariaLabel: 'Flip card'
<script src="https://code.beaverhero.com/textblock/0726c10v1fliptextblock.js"></script>
<style>body.sqs-edit-mode-active .ftb-card > .ftb-back {transform: unset !important;
}body.sqs-edit-mode-active #siteWrapper [data-ftb-side="back"]:not(.ftb-face){visibility:visible !important;position: relative;right: -30px;}</style>
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit current page > Add a Markdown Block
Add this code into Markdown Block
duration: 700,
axis: 'Y',
flipDirection: 1,
tapToggle: true,
