To make Portfolio items fade in on Scroll, you can use this code to Code Injection > Footer.
You can also use this portfolio tool to add Portfolio, so you can add animation effect easier without using complex code.
$(document).ready(function() {
$('.grid-item').css({
'opacity': '0',
'transition': 'opacity 0.8s ease-out'
function checkViewport() {
$('.grid-item').each(function(index) {
var element = $(this);
var elementTop = element.offset().top;
var elementBottom = elementTop + element.outerHeight();
var viewportTop = $(window).scrollTop();
var viewportBottom = viewportTop + $(window).height();
if (elementBottom > viewportTop && elementTop < viewportBottom) {
if (!element.hasClass('animated')) {
setTimeout(function() {
element.css('opacity', '1').addClass('animated');
}, index * 150);
checkViewport();
$(window).scroll(function() {
checkViewport();
$(window).resize(function() {
checkViewport();
