To make Event Calendar Popup appear when users click text in a paragraph, you can follow these.
#1. First, create a Page in Not Linked.
With Name/URL: Content Lightbox – /content-lightbox
#2 . Edit Content Lightbox page > Add 3 Event Calendar Blocks > Then find ID of 3 Event Calendar
In my example, we will have:
- Event Calendar 1: #block-yui_3_17_2_1_1740272913615_126852
- Event Calendar 2: #block-yui_3_17_2_1_1740272913615_146360
- Event Calendar 3: #block-dedc8f4dc5de98997aa5
#3. Edit Paragraph where you want to make Event Calendar Popup appear > Edit 3 Texts > Add URL > Use this URL format.
Make sure “Open in New Tab” is disabled
Text 1: #wm-popup=/content-lightbox#block-yui_3_17_2_1_1740272913615_126852
Text 2: #wm-popup=/content-lightbox#block-yui_3_17_2_1_1740272913615_146360
Text 3: #wm-popup=/content-lightbox#block-dedc8f4dc5de98997aa5
#4. Install Popup Plugin
and Footer
#5. Result
When users click text 1 >> Event Calendar Popup 1 will appear
When users click text 2 >> Event Calendar Popup 2 will appear
When users click text 3 >> Event Calendar Popup 3 will appear
