(Squarespace) Click Image - Open Project Info Popup
To make Project Info Popup appear when users click an Image, you can follow these.
#1. Find Project Info URL
In my example, we will have
Project 01: /portfolio-2/project-one-ephnc-4ycls
Project 02:/portfolio-2/project-two-llrgk-36ewf
Project 03: /portfolio-2/project-three-8zgh7-zkprz
#2. Edit Images where you want to make Project Info Popup appear > Edit 3 Images > Add URL > Use this URL format.
Make sure “Open in New Tab” is disabled
Image 1: #wm-popup=/portfolio-2/project-one-ephnc-4ycls
Image 2: #wm-popup=/portfolio-2/project-two-llrgk-36ewf
Image 3: #wm-popup=/portfolio-2/project-three-8zgh7-zkprz
#3. Install Popup Plugin
and Footer
#4. Result
When users click Image 1 >> Project Info Popup 1 will appear
When users click Image 2 >> Project Info Popup 2 will appear
When users click Image 3 >> Project Info Popup 3 will appear
@tuanphan,
:heart: :heart: :heart:
