Squarespace Accordion 2 Columns
Description
  • split accordion content to 2 columns, 3 columns, 4 columns
#1.1. Add text with symbol: ##break
Something like this
so code can break it to 2 columns
or something like this
so code can break it to 3 columns
#1.2. Hover on Page where you use Accordion Block > Click Gear icon
#1.3. Click Advanced > Paste this code
  • If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
  • You can also use this Accordion FAQ widget to create accordion into Squarespace, so you can adjust style easier.
<!-- 07.26c28v6 Accordion 2 Columns -->
window.AccordionColumnsConfig = {
  fullWidth: true,
  breakMarker: '##break',
  maxColumns: 4,
  columnGap: '40px',
  columnMinWidth: '220px'
<script src="https://code.beaverhero.com/accordion/0726c28v6accordion2columns.js"></script>
#2. Customize
some style options (line 06 – line 08)
maxColumns: 4,
columnGap: '40px',
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can add a Markdown Block under Accordion Block
Then add this code into Markdown Block
  fullWidth: true,
  maxColumns: 4,
  columnGap: '40px',
