Social Feed of Specific posts from costumers
The ability to make a Social Feed overview of specific posts from customer accounts.
This way you can build a social recommendation wall from posts of people / accounts that talk about your product.
Hi there @JosG :wave:
I’ve checked your widget and see that you’ve added incorrect links to your LinkedIn posts.
Here is how you can find the correct version:
So, please try to use these links instead:
  1. https://www.linkedin.com/posts/devworld-conference_bryntum-helps-the-world-stay-on-schedule-activity-7200863489316311040-XVaV?utm_source=share&utm_medium=member_desktop
  2. https://www.linkedin.com/posts/devworld-conference_devworld-activity-7201329261067087872-eDpu?utm_source=share&utm_medium=member_desktop
The 2nd post isn’t displayed in the feed because of the cache. Our widget uses a cache system to make everything load faster and reduce the server load. So the posts are updated every 48 hours.
If it’s been more than 48 hours and the post still didn’t appear, please let me know and I’ll be happy to help :slightly_smiling_face:
