Slider pin to change the amount and minimum amount to donate
Ability to change the amount by adjusting the slider pin. Also, set the minimum of the amount to donate
Hello there @Poomin_Singhakhumpon :wave:
Your ideas do sound like a great addition to the widget, and we’ll try to consider them in them future. We’ll update you here if any news comes up :slightly_smiling_face:
