Issue description:
I’ve got Slider installed on my Squarespace website and it seems fine on desktop but it’s not showing the full content on mobile -
masarvideo.com/abm#casestudies
Hi there, @Brenden_Masar
It seems to be a bug with the Height by Content feature. I’ve forwarded this issue to the devs and will update you once it’s fixed
Any update on this?
We’re still working on the global solution, and it’s going to be release quite soon. As a temporary fix, we’ve added this code to the Custom CSS field on the Advanced tab of your widget’s settings:
[class*='WidgetBackground__Container-sc'] {
height: max-content!important;
.eapp-slider-slider-slider {
.eapp-slider-pagination-component {
background-color: rgb(116, 153, 62);
Please check it out and let me know if the widget looks fine now
this works thanks
Great, you’re welcome
We’ve released a global fix, so you can remove the code from the Custom CSS field now
