SIDE NAV solution to OVERRIDE GOOGLESITES frame constraints?
  • Link to the paemphasized textge with the widget in question:
Hey there @MOHAMED13 and welcome to the Community :wave:
If I got you right, you are experiencing the issue with the WhatsApp Chat widget not working correctly on the Google Sites platform.
Due to the peculiarities of the Google Sites platform, all popup and floating elements of apps (including WhatsApp Chat) are not supported. They are being converted into iframe format, which causes incorrect displaying.
However, you’re totally free to change the widget’s position to custom in Settings → Position and then embed the widget to a certain spot on your website:
If you change the widget’s position to embed and still have trouble installing the widget, please check this article - How to add Elfsight widget to Google Sites website
If I misunderstood you or the issue still persists, please elaborate on your use case and send a link to the page where your widget is installed. I’ll be happy to check it for you :slightly_smiling_face:
