To make Promotional Popup shows on Blog Posts only in Squarespace, you can do these.
#1. First, you need to enable Promotional Popup
#2. Next, use this code to Custom CSS
div.yui-popup-container-node {
display: none;
body[class*="type-blog"].view-item .yui-popup-container-node {
display: block;
