To make dropdown menu appears on click, not hover on Squarespace, you can follow these.
#1. First, use this code to the Custom CSS box
div.header-nav-folder-content {
display: none;
#2. Use this code to Code Injection > Footer
$(document).ready(function() {
$('a.header-nav-folder-title').click(function(event) {
event.preventDefault();
var $boxSub = $(this).closest('.header-nav-item--folder').find('.header-nav-folder-content');
$boxSub.toggle();
