Show description previews for all podcasts right away (without clicking the button
For me this only shows an info “i” icon on the right, is there a way to set it to show a preview of the text without expanding to show all the description?
Hi there, @Brian_Krebs :waving_hand:
Just to confirm if I got you right:
  • you’d like to remove the “I” button
  • the preview of description should appear right away
  • the full description should be expanded when clicking on the See More button
Is everything correct?
Yup you got it!
I’ve discussed your use case with the devs and, unfortunately, it’s impossible to customize the widget this way now. I’ve moved your idea back to the Wishlist and if it gets more votes, we might consider it in the future :slightly_smiling_face:
