Hello,
I’m working on building a widget with the week layout and was wondering if it’s possible to change the times shown on it to only include 6:00 AM to 9 PM? It’s defaulted to showing midnight to midnight right now.
Hello,
I see that on the desktop the half-hour event titles are fully visible, so you’d like to implement it on mobile only, right?
Got it, thanks!
I’ve passed it on to the devs and will update you once the solution is ready ![]()
Hi there, @lilykgamble ![]()
We’ve saved this CSS code in your widget:
.fc-timegrid-event-short .fc-event-main-frame{
flex-direction:column !important
.fc-timegrid-event .eapp-events-calendar-event-content-container{
overflow:visible !important
Please check it out and publish changes if you like the result ![]()
