Sendfox Integration
Integrate the subscription form with sendfox
Happy to see you’ve decided to join our ranks! Welcome @William1 :wave:
Thank you for sharing your suggestion!
We’ll try to take the Sendfox integration in our futre updates. I’ll keep you in the loop :slightly_smiling_face:
As a workaround, you can use Zapier integration where 5000+ services are available (including Sendfox).
Here is an article explaining how to integrate your Form widget with Zapier - How to integrate your Form widget with Zapier - Elfsight Help Center.
If you have any further questions, just let me know. I’ll be happy to help :wink:
