I see tickers making a comeback in new sites and would love to add the functionality. Great for highlighting multiple USP’s which we certainly have.
E.g. forkeepsmerch.com.au/
Hi there, @big_boppa ![]()
I guess our Logo Showcase widget with the Ticker layout should a perfect fit for you. Feel free to give it a spin and let me know if it worked for you ![]()
Thanks Max, we are using the logo showcase which works well, but I can’t see how I can use it in the ticker example I need. Here’s a website using one which weare trying to emulate:
I’ve checked your widget and see you’ve customized it similarly to the widget in your example:
Do I get it right that you need our assistance with the widget’s installation? If this is the case, please request the installation in your dashboard. Our Support Team will gladly help you with it ![]()
