Scrollbar in dropdown field
With many options in the dropdown field the menu extends the website instead of giving the abilty to scroll in the menu. This is not very user-friendly.
Hey there @user14145 :wave:
Your idea sounds reasonable, thanks for sharing!
I see that my colleague Viktoria has already shared a custom solution from our devs, but we’ll try to consider making this feature built-in in the future updates :slightly_smiling_face:
Guys, if you want to add a scroll to the dropdown field, paste this code to the Custom CSS field on the Settings tab of your widget’s settings:
[class*="Dropdown__DropdownContainer-sc"] {
  max-height: 400px;
  overflow: auto;
I added the following to the CSS code and this works well for me:
.kohGJb{
position: absolute;
top: 0px;
left: 0px;
overflow-y: scroll;
height: 50vh;
Hey there, @user3414 :wave:
A huge thank you for your involvement!
I’ve checked your widget and found that this code actually adds a scrollbar, but it’s not functioning quite right.
However, here is a general solution from our devs that should work great for all cases:
  max-height: 400px;
  overflow: auto;
