Instead of truncating the track title, make it scroll from right to left, so user can see the entire title of the track
I’ve discussed your case with the devs and they’ll try to customize the widget for you.
I’ll let you know once I receive a response from them
Thank you for waiting @Raymond_Wade!
Our devs suggested adding a scrolling animation for the titles in your widget.
Here are 2 variants:
Could you please let me know if you like these animations? If yes, which one would you prefer to implement to your widget?
I prefer the bottom where it starts on the left side. That way the user will see the title on load and not have to wait for it to scroll across.
Got it!
I’ve shared your feedback with the devs and will get back to you once the solution is provided
Thank you, I appreciate it. If they can add or allow a toggle option to loop the scrolling indefinitely, that would be an awesome bonus
Okay! I’ve shared this addition as well. Hopefully, our devs will find a way to loop the animation
Please add this code to the Custom CSS field on the Style tab of your widget’s settings:
[class*="Small__Title"] {
width: fit-content;
white-space: nowrap;
text-overflow: initial;
And this script should be added to the Custom JS field:
const duration = 6000;
let animation = null;
const animate = () => {
setTimeout(() => {
animation?.cancel();
const title = document.querySelector('[class*="Small__Title-sc"]');
const titleWidth = Math.floor(title.getBoundingClientRect().width);
const parent = document.querySelector('[class*="Small__Info-sc"]');
const parentWidth = Math.floor(parent.getBoundingClientRect().width);
if (titleWidth > parentWidth) {
animation = title.animate({
transform: ['translateX(0px)', 'translateX(0px)', `translateX(-${titleWidth - parentWidth}px)`, `translateX(-${titleWidth - parentWidth}px)`],
offset: [0, 0.1, 0.8],
iterations: Infinity,
duration: duration,
delay: 1000,
}, 100);
let i = 0;
const check = () => {
if (component) {
res(component);
} else if (i !== 50) {
setTimeout(check, 100);
i++;
check();
waitForElement("[class*='Small__Title-sc']")
.then(() => {
animate();
const button = document.querySelector('[class*="Prev__Component-sc"]');
button.addEventListener('click', () => {
animate();
const next = document.querySelector('[class*="Next__Component-sc"]');
next.addEventListener('click', () => {
animate();
const tracks = document.querySelectorAll('[class*="PlaylistItem__PlaylistItemComponent-sc"]');
tracks.forEach((el) => {
el.addEventListener('click', () => {
animate();
Please check it and let me know if you like the result
