Same email can be used more than once
Is it possible to turn off same email being used by one person?
Hi there, @Lubomir_Kalisky :wave:
Our widget doesn’t have a restriction for the number of times the same email can be used to participate. However, 1 user can spin the wheel only once.
Do you want to allow 1 user to spin the wheel multiple times? If it is, could you please describe your specific use case and why this feature would be helpful to you?
