I have a popup for the next couple days on this page: www.arboristserviceskzoo.com
I was trying to add rounded corners to the popup and looked everywhere but I can’t find where this setting is. I assume it is there.
Thanks.
Thanks.
Hey @Hugh! ![]()
I’m glad to say that you can make the rounded corners right in the widget settings. Go to the Builder tab and click Background:
Here, you’ll be able to change the Corner Radius:
Please let me know if this helps ![]()
Perfect! I knew it was there somewhere. I changed the background color but missed that option! Thanks!
Dear @Hugh, I’m glad to know that my instructions helped you! ![]()
