Provide an option to easily move your show result option from top to bottom. For example, I wish to move the total value amount to the top of the results and the processing fee to the bottom; there should be arrows to easily move the positions of your result section around.
Hey there and welcome to the Community, @Orenda_FinancialServ ![]()
Glad to say that you can easily change the position of the calculations using the drag-and-drop option:
Please check it out and let me know if it worked for you ![]()
