Issue description: Double-booking
Love, love, love the appointment booking app! When I book a date and time for a service, it’s not disabled or made unavailable for the next visitor. This creates the potential for double-booking. Is there a way to make a booked time slot unavailable for the next visitor?
Hi there, @user25591 ![]()
I’ve forwarded the issue to the devs and will update you once it’s fixed ![]()
In the meantime, you can connect the widget to your Google Calendar. With this integration enabled, the reserved slots will disappear from the widget - Syncing Google Calendar with the Appointment Booking Widget - Elfsight Help Center
Thank you, Max. Unfortunately, each service is provided by a different person, and not all of them have Google Calendars. If it were just me and my calendar, the integration would be great.
Got it, thanks!
Really hope the issue will be resolved soon. I’ll keep you updated ![]()
Hi @user25591 ![]()
We’ve looked into the issue, and it appeared there was some miscommunication with the dev team. The reserved slots won’t disappear from the widget unless the Google Calendar is connected — this is expected behavior.
To block reserved slots, you’ll need to enable the Google Calendar integration. I apologize for any confusion this may have caused ![]()
Let me know if this clears things up or if you have any other questions. I’ll be happy to help!
Thank you.
You’re most welcome!
We’re always here to help if anything else comes up ![]()
