Required number field in calculator form erroring out
I just tested on my end and i also see your issue. Not sure why, but i think the best solution is to turn it into a regular text field for now. It’s not just you, i also did a test with the calculator form.
Hi @user13755 and welcome to the community!
We’re very sorry for this inconvenience, and thank you for reporting the issue! Our devs have fixed it, so everything should be working correctly now :pray:t2:
Could you please check it on your end as well?
