Requesting a sub section in menu
Can there be a sub-section in menu . We have a Global fusion menu and our entree is sub divided into different continent like Europe, Latin. Africa and so on.
Hi there @RANTI_OLUWADARE :wave:
Could you please send me a direct link to the page where your widget is installed? It would help me better understand your case and check if there is a possible workaround :slightly_smiling_face:
This is the link. Currently trying your app out to see if it is right for our restaurant. To better have an idea of my request, if you check the Entree section you see that are open and closed brackets in front of the menu and also the Wine list which should have sub sections like RED, WHITE AND SPARKLING.
Thank you for the link!
Now I completely get where you are coming from, but, unfortunately, there are no workarounds to implement your idea at the moment.
If more users support this request, we’ll try to consider this opportunity in the future. We’ll keep you in the loop :slightly_smiling_face:
Thank you Max for the reply. Can the section tab have a caption added to it?
Hi @RANTI_OLUWADARE :wave:
If this feature gets more votes, we’ll try to think about this option too :slightly_smiling_face:
