Max
Add this code to the Custom CSS field on the Style tab of your Photo Gallery widget’s settings:
.es-embed-root {
padding: 0;
Guys, if this code was helpful to you, please drop a line in the comments. Your feedback helps us improve our services and provide better solutions
Hello! How can I add padding to the top and footer? Thank you!
Max
5
Hi there, @Ross_Diane_Limos
Here is the adjusted code:
.es-embed-root {
padding: 20px 0;
Please try it out and let me know if it worked
THANK YOU! IT WORKED! Love it! thanks guys!
Max
7
Happy to know that! Thanks a ton for the feedback, @Ross_Diane_Limos
JoJo
(JoJo)
9
worked perfectly. thank you
Max
10
Happy to see you on our forum @JoJo
Oh, that’s a pleasure to know - thanks a ton for your feedback
